Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Domanda Chiusa
SATA Port 2 is already taken!
Hi,
I'm in the middle of trying to use your guide to install a secondary SSD drive in my 2011 iMac. When I got to Step 33 where it talks about putting the supplied SATA cable into the Port 2 slot, there is already a cable in there, one that looks to be connected to my current hard drive. The cable that is in Port 1 is the other side of the optical drive plug I took off earlier. The optical plug is not the right size for the socket, in fact, it looks like it fits the slot marked SATA 0. What does this mean? Did someone miswire my computer or was this intentional?
As nothing like this is mentioned in the directions, I didn't want to move anything just yet before asking to see if this was at least normal or not. Any help would greatly appreciated.
Thanks,
Carmen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The problem is you can't see them without fully pulling the logic board out. If you have a small mirror you can see them.
  • The bottom connector set is two side by side connectors for the HD (discreet SATA & Power) {Port 0}.
  • The next one up is the optical drive combo SATA/Power cable {Port 1}
  • And the top most is the SSD combo SATA/Power cable {Port 2}.
If someone worked on your system before they could have put the optical drive cable into the wrong SATA port the system doesn't care which of the two combo ports you have what.
Punteggio 2
1 Commento:
Thanks, that's all I needed to know!
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 265
