Salta al contenuto principale
JBL Flip bluetooth speaker.Portable wireless speaker that is great when you are on the go. Released September 14, 2012 *Note not the JBL Flip 2
27 Domande Visualizza tutte
Domanda Chiusa
Why does my speaker lose connectivity when more than 5 feet away?
The speaker loses connection with the audio device that it is paired to when the two devices are more than 5 feet apart. This problem occurs with every device that is paired to the speaker.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
More than likely the speaker's original antenna has grown weaker over time or your device came with antenna out of the box that was not up to par with the quality that it should have been. To fix this issue the back plate of the speaker will have to be removed and the internal parts will need to be accessed. for further assistance with fixing this problem please refer to the guide by using the following link: JBL Flip Bluetooth U.FL Antenna Connector Replacement
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,383
