Salta al contenuto principale
-Obiettivo con attacco EF -Intervallo di apertura: f/3.5-36 -Stabilizzazione ottica dell'immagine -Motore di messa a fuoco automatica ultrasonico -Sistema di messa a fuoco interno -Modalità manuale continua -Distanza minima di messa a fuoco: 50 cm -Diametro della filettatura del filtro: 72 mm
3 Domande Visualizza tutte
Canon 28-135 f/4.0 IS USM Lens resist on turning
Hey guys
i totally no idea why does my lens resist on twisting whenever i zoom in or zoom out, i does require a certain amount of force just to twist the barrel of the lens.
how to fix this?
Questa è una buona domanda?
Punteggio 4
1 Commento
I have the same problem and it has gotten worse to the point that the lens is almost unusable
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hello Jan!
if the barrel is broken, you will need to replace it and additionally buy the CANON EF 28-135MM F 3.5-5.6 IS BASE ZOOMING GUIDE by $6 USD
http://www.procamerarepair.com/search.as...
i EXPECT can be usefully my answer.
good luck!
Punteggio 3
The same thing happened to my lens and I tried to zoom in and zoom out forcefully and suddenly it snapped and a ring broke in my lens so don't try to apply force. I watched this video on YouTube to fix my lens but I seriously advise you to get it fixed if you don't want to try to fix it by yourself still I am copying the link to the video. Hope this helps.
https://youtu.be/PMUXqfTEXsA
Punteggio 2
my lens is stuck at 135, i mean it believes that is at 135 even though i am at 28, anyone knows something about that?
Punteggio 2
It could be that the lens threads are out of position with a slightly bent lens.
This has helped me getting it fixed, maybe that also helps others
https://www.youtube.com/watch?v=_4K1Ge5C...
Punteggio 2
Aggiungi la tua risposta
Jan Buencamino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 4,119
