Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Domanda Chiusa
must have damaged the touch-ID.
bump. Same problem here. Tried replacing the metal shield with the cable connecting touch ID to the logic board with several original flex cables, still no luck. I take it my colleague must have damaged the touch-ID. Is there any workaround?
UPDATE: I swapped the home-button for a button laying around in the shop, possibly the original one and it worked.
Anyone know if the same goes for iphone 5s where you swap home button? Got a customer with working touch ID but defective button but don't want to have to put the original back in every time she updates.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Unfortunately not
Punteggio 0
For iPhone 5s, the phone won't die if you reinstall iOS without the original home button, you'll just lose Touch ID.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 134
