Salta al contenuto principale
Repair guides and support for phones manufactured by Lenovo.
My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
Questa è una buona domanda?
Punteggio 15
3 Commenti
lenovo a7000 switch solution
da
my phone was not getting charged more than 15% and now it cant be switched on? plz help
da
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
da
Aggiungi un commento
7 Risposte
Risposta Più Utile
Punteggio 3
I faccing same problem
help to out me from this problem
Punteggio 1
2 Commenti:
Facing same problem.
da
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
da
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
Punteggio 1
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
Punteggio 0
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
Punteggio 0
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
Punteggio 0
My power button was broken
Punteggio 0
Aggiungi la tua risposta
arjnkar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 14,414
