Salta al contenuto principale
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Domande Visualizza tutte
Ipad mini not turning on and not being detected by itunes
After I did the screen replacement, the iPad wouldn't turn on, but since its happened to me before I know that i just had to disconnect the battery and reconnect it and would turn on, but it didn't. I then went to go check if iTunes would recognize the iPad,and it didn't recognized it. I've worked with ipad for over a year now, and this has never happened to me. I am for sure that no metal touched the mother board; i only use plastic when it comes to lifting up the cables. Is this fixable? What can I do?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
I am having the exact same issue. the only difference is when I disconnect the lcd itunes will recognize the ipad. did you ever fix this issue?
Punteggio 0
Aggiungi la tua risposta
Ricardo Zapata sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 184
