Salta al contenuto principale
The Olympus Stylus Tough 6020 combines advance imaging components with a rugged build so it can go along wherever your adventures may take you.
3 Domande Visualizza tutte
My camera will not turn on, what do I do?
I keep trying to turn the camera on but it seems to be getting no power and I have not even gone underwater with it yet, so I know it is not due to water leakage. What do you recommend?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Please check and confirm the battery is fully charged and is seated properly withing the battery compartment.
Punteggio 1
I have the same problem I turn it on unit makes a clicking noise and beeps then shuts itself down. Have a new battery fully charged.
Punteggio 0
1 Commento:
Same deal! Mine is at least ten years old and eventually started doing this a few years ago, even with a full battery. Wondering if it was a part that went bad over time due to extreme heat/cold or leaked while underwater as it has seen all of these conditions. I will dig into this and hopefully find an answer.
da
Aggiungi la tua risposta
Taylor Carabin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 645
