Correct drive kit for upper bay
I want to install an additional drive in the upper bay....closest to the top of the mini when it is operation. The factory drive is in the lower bay...next to the bottom cover. Which kit do i need to get the correct sata cable? Thanks
Questa è una buona domanda?
1 Commento
If you buy the kit mentioned in Dan's reply you will wind up with two lower bay cables. Worth asking but it seems that fixit may not sell the upper bay cable (they seem to assume that the OEM drives always come in the upper bay. I bought my Mac Mini (late 2012) from Apple's refurb store so it's possible they had two drives in the box and simply pulled the bottom one when refurbishing the box. The upper cable by itself can purchased from several vendors but the cost for a real OEM quality cable is more than the dual drive kit (sans driver and bits). I wonder if I can get by with a cheap knock off without the temperature sensor (since the original cable probably has one)?
da Gary Wasserman
