Salta al contenuto principale
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
its stuck talking a foreign language
My apple ipad2 it stuck in a foreign language I've tried several things please help
Questa è una buona domanda?
Punteggio 0
2 Commenti:
What have you tried so far?
da
i need to change the launge on tablet
da
Aggiungi un commento
4 Risposte
Tapping the "home" button three times in a quick sequence should turn it off. :)
Punteggio 0
1 Commento:
Hello but that is for quick access for the options you asked to turn on like assistive touch, voice over or invert colors but not language
da
Hello you may have changed or someone changed your text language so this is what you will do: (P.S. I am using ios 8 so you might probably experience some difficulties if you are not using ios 8) First go to settings which looks like a gear, then press general which also looks like a gear and then in the 8th group last icon is saying language and then press it and the first icon will say ipad language, press that then change the language to english
Punteggio 0
Oh and yeah this might help you, language and region is just near the reset button
Punteggio 0
can u tell me how to change the launge
Punteggio 0
1 Commento:
Aggiungi la tua risposta
Barbara Beck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 986
