Salta al contenuto principale
Why my laptop is getting hot?
My laptop is getting hoter how can i cool it down?
Questa è una buona domanda?
Punteggio 15
Aggiungi un commento
6 Risposte
Risposta Più Utile
Hello,
Your laptop can be hot due to a broken heatsink, the fan (and all the motherboard) can be full of dust or because the thermal paste between the heatsink and the processor is too old.
Regards
Punteggio 6
1 Commento:
Thank you for the information. That makes a lot of sense, I'll definitely check the fan and heatsink for dust buildup and consider reapplying thermal paste if needed. Appreciate the helpful advice.
da
Punteggio 2
When I turn on my laptop it's suddenly turn off I can't understand
How and why he turn off suddenly in few seconds
Punteggio 2
this is probably because of dust in the heatsink of the laptop, heres a link to fixing this problem http://www.howtogeek.com/194479/how-to-c...
Punteggio 0
My HP Elitebook 8540w was so hot I could have fried and egg on it. I went here and followed the instructions and it is cool now. Worth a try.
http://www.it-tutorials.net/hp-elitebook...
Punteggio 0
How do you use your Laptop? maybe the board process too many applications try to uninstall the software that you didn't use if it doesn't work try to reseat all the Hardware components.. and clean the motherboard using brush.. also the Heatsink and try to replace the thermal paste..
Punteggio 0
Aggiungi la tua risposta
alipanhwar13 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,731
