Salta al contenuto principale
Nel 2012, Sony annunciò che la società avrebbe rilasciato una nuova versione della sua console PlayStation 3 del 2006. La nuova console fu chiamata PlayStation 3 Super Slim ed è identificata dal numero di modello CECH-4000. La PlayStation 3 Super Slim (CECH400x) è la terza versione della console per videogiochi PS3 prodotta da Sony Computer Entertainment. Fu lanciata sul mercato il 25 Ottobre 2012.
20 Domande Visualizza tutte
Where to buy flex ribbon cables?
I've been searching on eBay for all 4 flex ribbon cables that my PS3 Super Slim CECH-4001B uses, but I have found only ONE cable that is from that model.
Will these work?
Two of these 6-pin, one for the power button and the other for the lid open/close switch.
http://www.ebay.com/itm/Hot-6-pin-Eject-...
One of this 9-pin, this one goes under the power supply.
http://www.ebay.com/itm/NEW-9-Pin-0-5mm-...
And this 45-pin one is for the BluRay.
http://www.ebay.com/itm/Flex-Ribbon-Cabl...
Will the first two fit? are they too expensive?
Questa è una buona domanda?
Punteggio 3
2 Commenti:
Did these cables work for you? I need a 9pin flex cable for my Super Slim.
da
Unfortunately I never got around to buying any, I convinced myself they were too expensive and decided to give up on my PS3.
da
Aggiungi un commento
4 Risposte
I need a ribbon for the super slim that hook up under the power supply to the disk motor not for the laser please help me idk how pins it has pleasel et me know
Punteggio 0
1 Commento:
That's a 9-pin connector.
da
Was a 9-pin accurate?
Punteggio 0
To anyone going through this problem the ribbon cable is a 9 pin forward 1.0 mm pitch 50mm length flex cable they can be obtained from eBay but from China
Punteggio 0
2 Commenti:
PS all cables are like $10 for Blu-ray
da
Do you know the pitch for the 45pin as well as the 6pin cables as well?
da
I have a question.. Hoping someone can help me.. I'm trying to figure out what white cable that is to the left of the disc reader is so I can purchase it!! So I can buy the right one
Punteggio 0
Aggiungi la tua risposta
Gabriel Velez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 5,685
