Salta al contenuto principale
A business-class desktop PC, sold in multiple form factors and configurations.
when I press the power button nothing happens.
There is an led on the MB indicating that it has power but when i press the power button nothing happens. All the cables are connected and there is no visible damage to the motherboard and other components.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
6 Risposte
I would check power cord first...then check the power connection
Punteggio 0
Hi guys, I have the exact same problems. I have checked the psu and power connectors, and the front card power button, they are all fine. The bios chip gets really hot though.
What can I do?
thanks
Punteggio 0
1 Commento:
my guess would be electrolytic capacitors in the power supply are going bad
purchase another similar P.C - put your hdd & ram in it - doesnt cost much
da
Replace the motherboard. It'very easy. While doing that add 3.8 processors and AMD 5450 video board. Put all 4 gigs of memory. Add 1 terabyte hard drive. Install Windows 10 and you,'ll have a nice running computer. But the motherboard alone will solve your problem, You can get them cheap on EBay.
Punteggio 0
I’ve had the same problem and I have a answer for it. There should be a green pin inside and if it’s on the “RTCRST” pin move it to the “PSWC” pin and that will work.
Punteggio 0
Brother this is problem of your front Power panel card unplug the front button power card and on PC directly or replace front card of power!
Punteggio -1
check processor chips
Punteggio -1
Aggiungi la tua risposta
Joran Geeraerts sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,994
