Salta al contenuto principale
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
17 Domande Visualizza tutte
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
Questa è una buona domanda?
Punteggio 6
2 Commenti:
What does Apples AirPort Utility tell you?
da
Did you get things working?
da
Aggiungi un commento
1 Risposta
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Apple AirPort Extreme Model A1354 Antenna Replacement
if you need to replace the WiFi card, here is the guide for that.
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Immagine Apple AirPort Extreme Model A1354 Antenna
Guida
Difficoltà:
Moderato
5 minutes
Immagine Apple AirPort Extreme Model A1354 WiFi Card
Guida
Difficoltà:
Moderato
10 - 15 minutes
Punteggio 0
Aggiungi la tua risposta
wmathie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,193
