Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Will the 2010 MBPro Screen fit a 2011 MacBook?
I need to replace the display on my Late-2011 macbook, and both time and money are at a premium. I've found an affordable example which will arrive in good time but it's from the 2010 model MacBook, and mine's the late 2011.
Will this screen fit, and work?
Questa è una buona domanda?
Punteggio 0
1 Commento
I got around this problem by taking the glass from the 2010 keeping the 2011 assembly painful long process but works .
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
LCD, yes.
Full assembly, no.
2008 A1278 model uses an LCD assembly with the sleep magnet on the other side than the 2009/2010/2011.
2009 assembly and 2010 assembly are same thing, but wifi wire is 1 or 2mm shorter on one vs. the other.
2011/2012 assembly use different webcam, different webcam cable. Also these do not have wifi card in the lid, and they use a different wifi antenna which will not fit in the clutch cover.
So LCD, yes. Glass, yes. Entire ASSEMBLY, no.
Punteggio 6
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,234
