Salta al contenuto principale
Computer che in generale non comprendono uno schermo integrato e sono pensati per essere usati in postazioni fisse.
2133 Domande Visualizza tutte
Networking, Lan,Network and sharing center
I have Three Desktop PC joint with D-Link ethernet hub, and two of this PC also connected through wifi modem for internet use. I use Cisco wifi reciver dongle for internet connection.
Problem is when i transfer file from one PC to onther pc .. file not going through lan cable but it use wifi dongle to send fil. So it become slow file transfer.
How can i configure networking ..?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Windows doesn't offer biasing with dual homing (your configuration here). So you can't have both connections active.
Another option here is to turn off the WiFi services so the desktop systems use the Ethernet connections only. Then connect the Ethernet hub to your internet router wired or via a WiFi Router to the Cable modem's WiFi AP. That way the connections are faster for both file sharing and to the internet.
The other option here is to have only on of the desktops connected to the both Ethernet & WiFi (multi-homed). Then you'll need to setup pass-though services making that desktop as a router for the other two systems.
Punteggio 2
Aggiungi la tua risposta
pankaj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 85
