Battery not charging after screen replacement
The cracked screen was replaced and after reassembly it booted up normally.
Following that it is not recognised by a laptop for charging and did not power up normally after some time plugged in.
The battery is now flat and the phone unresponsive, what will fix this?
note: I also tried charging through another compatible micro to USB connector which did not work.
Questa è una buona domanda?
2 Commenti
I also have the same problem i have tried replacing the pcb or charger board after the digitizer was replace and still not working :S strange problem hope we find a fix!!!
da chris ormiston
Thanks Ben i did think that myself but wasn't sure. Anyway got one for £2 and it worked! So thanks again i probably wouldn't have bothered trying if you hadn't said that :)
da chris ormiston
