back breaklights dont work,all other lights do. not a fuse or bulb.
need wiring diagram or hints to the problem.
Questa è una buona domanda?
The brake switch is located behind the brake pedal attached to the push rod..It could be faulty or stuck. Because its an important component I would replace it even if you find it's just stuck.
The Diagram is on this page...
Can see the diagram third brake light works nothing on the rear.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 599
Would the thrid brake light stll work with the brake switch blown?
da Roger Blankenship
