Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Is the front assembly metal panel necessary?
I have lost the metal panel in the top right of the phone that covers all the connector cables, is this a necessary piece to have to have the phone work? If it is, where can I buy one?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You can use without but the purpose of that part is to keep the connected pressed down so if the phone was dropped its possible they could pop out
Punteggio 1
Risposta Più Utile
Nothing is necessary, everything has its purpose.
Punteggio 1
1 Commento:
So is it needed to actually use the phone or not?
da
When you're out jogging, your phone might stop working because the display came loose. Or if it falls off your bed at night---that kind of thing. So open it up and plug in the connectors. Personally, I take my own phone apart so much wherever I go for demonstrations, I never keep all that stuff on there. My battery comes unplugged, but not so much the lcd/digit/prox flexes.
Order it from china for 50 cents on eBay and just let it take a month to get here.
Professionally, I always fill in those small parts so that phones leave with all the right pieces. It is just a matter of personal preference.
jessa
Punteggio 1
Aggiungi la tua risposta
Ryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 85
