Replacing lower back cover MacBook A1342
I'm in the process of replacing the lower back cover of my MacBook A1342 late 2009 and rather than buying the ruberied back cover I would like to replace it with a MacBook Pro 13" Mid 2009 or 2010.
My question is quite simple. Is it possible to do so or does the holes for the screws not in the same positions?
Thanking you in advance for your response.
Questa è una buona domanda?
3 Commenti
Apple had two version of this model. Looking at the case's serial number can you tell is the information is on a single line or on two different lines.
da Dan
basically both the late 2009 and 2010 models uses the same cover.
da fabricesheik
@fabricesheik - Well sorta... I have two different P/N's one of the earlier model of this series and one for the newer one which spans across to '10. So without knowing the the case information is setup (asked above), its a guessing game.
da Dan
