Salta al contenuto principale
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
DDR3 1333mhz work on this model?
Hello!
In our store I'm win two 2gb modules of DDR3 1333mhz RAM (so-dimm). This memory can work in this mac mini (A1283)?
Thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
wow! I'm insert memory and mac mini works fine! Thanks!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Even in the 2010 Model of Mini, the system bus is 1066Mhz, so I believe that you can use this RAM, but your system is only going to recognize 1066mhz, its an EFI limitation on your logicboard itself. On a PC you would be able to fiddle around with the bios and allow the machine to recognize all 1333 MHZ, but the difference wont be noticeable. I wouldn.t recommend that you use RAM that isn't exactly specific to your mini's specs. If you have a 2007 or earlier model then the memory is DDR2, which is definitely not compatible with the RAM u mention.
Punteggio 3
1 Commento:
Another important factor is that your Mini takes 204 Pin memory sticks, make sure the memory sticks you have match those specifications.
da
Hi! I just use 2x4GB (8 GB) Corsair DDR3 1333 Mac Memory and works fine. My Mini is a 2.26 GHz model.
Punteggio 2
Aggiungi la tua risposta
Mikhail sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,740
