Salta al contenuto principale
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
20 Domande Visualizza tutte
Note 3 imei certificate fail
I can not make calls or receive it says fails to register on network I upgrated also to version 5 . The phone was root before and also was having the same problem ( I try and manual to register it finds the local providers but it's fail to register , I try and few SIM card )
When I try the code *#0011#
The
Imei certi : fail
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
4 Risposte
i am having the same issue if find how to fix it pls send me a way on my email and ty my email anas_mukresh_1996@hotmail.com
Punteggio 0
1. Please make sure the email account is correct when you registered samsung account.
2. Land on the email, check the junk mail, check whether the validation email be intercepted.
Punteggio 0
my phone imei null..phone is root
Punteggio 0
Buy a chimeratool 3 day license. Activate usb debugging under developer options(tap buld number about 7 times). root the phone and after that do imei repair with the original imei under the battery.
other alternative is to make a new falsh with odin. you can get the firmware from sammobile . this method will delete all your information so make sure you do a backup first.
Punteggio 0
Aggiungi la tua risposta
christis1975 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,823
