Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Domanda Chiusa
Can I replace my trackpad with one from a different model/size
I'm curious if you know if it is possible to replace a 13" MBP trackpad with one off a 15"? My 13"'s trackpad is cracked and my 15" logic board is toast. There seems to be different models available but the dimensions are exactly the same.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If we look at the P/N's they are very different:
MacBook Pro 13" Early '11 Trackpad 922-9773 - Here's the IFIXIT part: 13" Trackpad
MacBook Pro 15" Early '15 Trackpad 922-9749 - Here's the IFIXIT part: 15" Trackpad
As you can see the trackpads are the same within the different series from '09 ~ '12 models so you could use a 13" junker instead.
Immagine MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Prodotto
$59.99
Immagine MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Prodotto
$59.99
Punteggio 0
1 Commento:
I was just hoping that since they are the same dimensions they would work
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 94
