Salta al contenuto principale
Released in September 2010, the Roku XD is the first generation of Roku’s video streaming set-top-box. The Roku XD is identified by model number 2050X.
4 Domande Visualizza tutte
Why won't my Roku turn on?
There is no power to the Roku.
Questa è una buona domanda?
Punteggio 33
41 Commenti
I was having same problem tried everything and got fixed by restarting devices once.If still having problem might be your account issue, may contact on 18005852494 and get update about everything.
da
My ROKU TV is not powering on at all. What can I do?
da
ok. so my tv wont turn on either. The light at the bottom of the tv is on but if I try to power it on it shows nothing. The light will not even flash at me. I have tired a new outlet and unplugging and plugging back in. I have also tired to turn the tv on by remote and by the button on the back of the tv. not sure what else to do. ANYTHING that anyone can think of will help.
da
I have the same problem
da
I've got that problem as well and I found out that if you disconnect HDMI port #1 it will turn on try that
da
Mostra altri 36 commenti
Aggiungi un commento
16 Risposte
Soluzione Prescelta
If your Roku device will not turn on, the first thing to do is to make sure that the device is plugged in and that the power cord is seated properly. If you've done this and it still won't turn on, don't panic. You can consult the Roku XD troubleshooting page for more possible solutions.
Punteggio 8
9 Commenti:
I solved my problem by turning off screen saver on roku
da
How do you turn of screen saver. This only happens when i FIRST TURN IT ON
da
Striped screen, any ideas?
da
Roku come on but no picture
da
haven't had a problem lately but when my roku tv did not come ON b4, I would unplug the power cord for a a couple minutes and it worked. don't know why roku does that??
da
Mostra altri 4 commenti
Risposta Più Utile
From Roku troubleshooting:
Roku XD 2050X Troubleshooting
Remote and Roku Need to Be Reset
Remove batteries from the remote. Hold down every single button on the remote for five seconds. Then, replace the batteries.
Next, unplug the power cord from the Roku, wait for five seconds, plug the power cord back into the Roku, and wait for Roku banner.
Ridiculous? Yes. Did it work? Also yes. :)
Punteggio 9
23 Commenti:
Didn’t work for me
da
Worked! Thanks. Wonder why/how this fixes the problem.
da
Didn’t work for me.
da
I unplugged all cables to my modem, waited 30 secs, plugged everything back in and everything is fine now.
da
Did not work
da
Mostra altri 18 commenti
Yep unplugged the TCL Roku tv and wouldn't power back on. Just for giggles I followed one of the instructions above. Hold all the buttons down at once. Bravo! It
Punteggio 2
2 Commenti:
This didn't work for me.
da
thank you, thank you, thank you!
da
If your Roku device is not getting on then you need to be reset both Remote and Roku device.
To reset your Roku remote,follow these steps:
  • Hold down every single button on the remote for five seconds.
  • Then, replace the batteries.
  • To reset your Roku device , follow these steps:
  • Unplug the power cord from the Roku, wait for five second.
  • Plug the power cord back into the Roku, and wait for Roku banner.
  • I hope these steps can help you to solve your query.
  • For more information click '''here'''.
Punteggio 1
4 Commenti:
This did not work
da
Do you have to hold down the buttons on the side also? The mute and the volume?
da
I tried unplugging, holding buttons, replacing batteries and nothing works I get the home page, but I can’t toggle to anything
da
I did everything and its still not working.
da
I've had the same problem try disconnecting all your HDMI ports and leave them unplugged until your screen goes to the home screen
Punteggio 0
2 Commenti:
My TVs off light was on but now it's off too. It won't power on or anything.... .. any advice
da
My problem also
da
I had this same problem. The light on the bottom was lit but the tv woulsn’tturn on. I tried the button on the TV as well as unplugging, and nothing changed. I don't understand why or how it works but I took the batteries if the remote out, held all the buttons down. Once I put the remote back together and pressed the power button it turned on! Weird.
Punteggio 0
4 Commenti:
This is crazy my light is on but it won't turn on I unplugged it dI'd the remote thing but still won't cut on any more suggestions for me please help
da
did you hold them all down at once
da
This actually worked!
da
It worked the first time I had this problem but wont work this time
da
I had a 1 year warranty and he came out and it was the motherboard needing replacement
Punteggio 0
1 Commento:
I did the remorte reset and my roku yesterday worked fine after but now same thing wont come on have been doing reset over 2 hrs now still no come on what to do now
da
We're is the fuse located on my tcl model 43s421 Roku I tooke the back panel off and can't seem to find the fuse
Punteggio 0
Technical issues with QuickBooks software are quite common. This blog gives a short and crisp information about what it means to seek help from right Quickbooks customer support phone number team. I came across this blog while I was looking to solve technical glitch with my QuickBooks on my own. But then, I got Quickbooks customer support phone number team’s number and got instant help.
Punteggio 0
This is a great inspiring blog. I am pretty much pleased with your good work. You put really very helpful information. If you face any issue, connect with the antivirus installation support team and get a step-by-step guide.
Punteggio 0
Follow these steps to solve your Roku device related issue:
  1. Hold down the every single button on the remote for five seconds.
  2. Replace the battery.
  3. Unplug the power cord from the Roku, wait for five seconds, plug the power cord back into the Roku, and wait for Roku banner
  4. If your Roku device is not getting on then you need to be reset both Remote and Roku device.
If you’re unable to turn on your Roku then you must take help from the experts. Click here if you’re looking for the help.
Thank me Later!!!
Punteggio 0
Tried all of the above without success. Tried bringing up the Source to change the setting to Roku manually (instead of hitting the Home button) That didn't work either. But one time I clicked on another HDMI Port by mistake--that didn't say Roku and not my TV channel--just had blank dashes--and the Roku channel came on! I also noticed that instead of showing my TV channel--Directv --that it said satellite. Each time I would try the Home button but would have to go to the Source to change it. After a few weeks I tried the Home button on the remote and Roku came on. I looked at the sources and instead of Satellite in showed Directv again. So I'm guessing it's something in my TV rather than Roku. I have a 9 year old Samusung.
Punteggio 0
Didn’t work for me at all. It won’t power on at all
Punteggio 0
The people would be able to manage their crucial transactional paperwork if they find out How To Delete Cash App History at once. There may be specific processes that must be carefully followed while deleting the cash app history. Users of cash apps should become familiar with these to ensure that they are using the system to manage their accounts properly. They can therefore communicate with the Cash App executives who handle the management of the Cash App account concerns effectively and regularly. However, unforeseen problems are frequent, so picking the appropriate approach will always be effective.
Punteggio 0
Strategies to search out Cash app bank name
If clients of the Cash application are considering how to recognize the Cash App Bank Name, they can initially enter the Banking page or they can likewise take a gander at the Cash Card. Nonetheless, it likewise has angles that clients should know about to keep using it on a case by case basis. So they might become familiar with the motivations behind the highlights that the money application account needs to give, they ought to scrutinize the care staff. That will end up being the most solid strategy for reaching out to the right realities about the money application. A great many people simply really like to deal with their monetary undertakings however much as could be expected utilizing computerized stages.
Punteggio 0
How To Transfer Money From Net spend To Cash Apply Linking It?
Are you really not aware of how to Transfer Money From Netspend To Cash App account? If you would like to do the same, you should first make sure you have Net spend routing number and account number. Apart from that, you also have to get in touch with the expert’s backing to link your Net spend account to your Cash App account. After that, you can easily send money to your Cash App account from a Net spend account without any trouble.
Punteggio 0
Aggiungi la tua risposta
William sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 213
Tutti i Tempi: 291,679
