Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
Switching HDDs/ Adding additional HDD
If I want to upgrade to a SSD and replace the existing HDD would you be able to replace the existing HDD with a 2.5" SSD? Also, would it be possible to purchase and install an additional SSD stick like the one that Apple puts in the units from the factory?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
You most definitely can replace the hard drive with an SSD to gain a performance increase. as for the ssd stick im not sure what you mean . are you referring to the fusion drive ? Take a look at this guide for more info and it may answer your questions. Mac mini Late 2014 Teardown
Punteggio 0
Aggiungi la tua risposta
mikeknafo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 240
