Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
How to fix backlight LVDS connector damage or baclight component
Hi, Is anyone can me? I have a macbook A1286 emc 2563 logic board number: 820-2915B which power on and we can ear the shime but no video and backlight. After looking at very well the lcd connector I saw that there are some pins (about 3 or 4) on missing on the logic board and the pins maybe burned I don't know why. I think it is the source of the problem, if itsn't what's the problem? Please I need the pinout of these missing pins to fix it when i'll change this connector by a new one.
regards
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Drickko, it's a definite that you will have to replace the connector. Yes, it most likely is the reason for your display not to come on. The bigger issue here will be why it burned like that. After you change the connector check the circuitry for short to ground etc. Contact 3 is the power to your LCD. your pins look like 40-36
Punteggio 0
2 Commenti:
I don't know the reason why it burned like that... can I have the pinout of these missing pins (there are no pins on the logic board to solder these pins burned)? Where is located the lcd power on the board...?
da
You can not repair the individual contacts but have to replace the complete iPex 20474-040E-11 connector
da
Mack pro A1286
this from damage place 4 pin is contact with soma place and the place is near light fuse under the ic light fast point
Update (10/12/2017)
Punteggio 0
Aggiungi la tua risposta
Drickko sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,664
