upgrading battery from 2800 mamp to 3200 mamp
is i can upgrade a battery with more power for my tab ?
Ex: 2800mamp to 3200 mamp ?
Questa è una buona domanda?
Mohammed Buhari sure you could if you can find one that fits your XTouch. Be aware of the scam with higher capacity batteries etc. Most of those are not any better than the standard batteries. You can try and search for a better battery based on the physical size of yours as well as the connector. Check reputable sellers only. Check this Le fantomatiche batterie ad "alta capacità" since it is still true today. Remember, higher capacity batteries also take longer to charge
Now Why? How do you upgrade a Battery’s MAH
IS A BAD IDEA TO DO IT!
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 178
