Salta al contenuto principale
The Asus VivoBook Q200E-BSI3T08 touchscreen laptop was manufactured by Asus in 2012.
12 Domande Visualizza tutte
How can I clean the fan?
Every now and then my computer will randomly shut off, usually when I have been using it for several hours. I think it is because there is dust in the fan?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Hi Jennifer,
Have you noticed any temperature problems? It's possible your laptop is overheating. Does it start to feel more hot than it should after a while?
Punteggio 0
If you would like to clean the fan you can remove the back panel using this guide: Asus VivoBook Q200E-BSI3T08 Back Panel Replacement and then you can clean the fan using either compressed air or a small, soft brush.
Punteggio 0
Aggiungi la tua risposta
Jennifer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 446
