Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Can I recover data from iPhone 5 with a broken logic board?
My iPhone 5S fried itself somehow. I just picked it up one day and it was hot and unresponsive. My computer does not recognize it. At the Apple Store, they told me the logic board is broken and that there's no way to fix it or get the data. Based on Googling, I'm guessing that's true, but I thought I'd ask. I wasn't backing up to iCloud. My most recent sync was two weeks ago, so I have most of my data, but there are some recent pictures I would love to recover. Is there any way to recover data from the phone?
Questa è una buona domanda?
Punteggio 0
3 Commenti
I know your situation and it heppened to me before. Don't panic, now you need to do is to install iPhone Data Recovery and launch it on your computer. And here is the guide about how to recover data from broken iPhone 5s. Just follow the steps. Good luck to you.
da
Don't worry, you still have chance to retrieve lost data from your broken iPhone, just try Moibledic iOS Data Recovery tool, Its powerful features make it to be heavily in demand as a data recovery program. iPhone Data Recovery can directly scan your iPhone to recover Camera Roll Photos, Camera Roll Videos, Photo Stream, Contacts, Messages, Call history, Calendar, Notes, Reminder, and even Safari bookmarks.
This is the guide on how to recover contacts from iPhone.
da
I Recommend you http://xfix.co.uk/ .
They are specialises in Dead iPhones/iPads and Water Damaged and Phones/Tablet Data Recovery & All Circuit Board Micro Soldering and board Level Repair in Middlesbrough, UK since 2007.
Web Site : http://xfix.co.uk/
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
there is no way of recovering unless the phone boots to main screen dont let anyone tell you different and spam you with recovery programs that will not work as the phone needs to boot to main screen
Punteggio 5
3 Commenti:
Thank you for the advice. I'll keep away from the scammers!
da
Yes their is its called Jtaging....
da
Unless you remove motherboard and attempt to install it into a working device.
da
If the CPU and main flash is intact, then in theory it is possible.
If the CPU and/or main flash is dead, Good luck beating AES256 then.
Punteggio 3
5 Commenti:
Thank you. How would I know if it is intact?
da
Yes you can if you know how to Jtag
da
He wouldn't be 'beating AES256' though. He's knows the encryption key already because it's his phone.
da
No, the key is derived from multiple sources including passcode, volume keys and CPU keys. He does not have all the details so he can never derive the final keys.
da
Yes you can, you don’t need to beat any encryption if you migrate CPU, EPROM, and NAND flash
da
If you don't have the backup file and your computer can not recognize your iPhone, you can not recover the photos from your iPhone 5.
Punteggio 1
cant you take out the storage and put it in a other iphone 5
btw i got the same problem motherboard is death and cant get my data
my phone is not responding just nothing
Punteggio 0
2 Commenti:
No. As I have already said.
da
That’s not true, if you remove the EPROM, cpu and nand flash and install those on a working logic boards you can get the data
da
Sorry to hear that. Maybe you can try some iPhone Data Recovery toolkit to recover them. You just need to run the program and connect you iPhone. There are three modes inside this toolkit. Maybe you can get further help in this tutorial about how to recover data from broken iPhone 5.
Punteggio -1
1 Commento:
@janes12 no software will work on a phone that does not power up.
da
Aggiungi la tua risposta
Jette sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 30,902
