Salta al contenuto principale
The Canon Powershot A1200 is a 12-megapixel point-and-shoot camera that uses an f2.8 28mm-equivalent wide-angle lens with a 4x zoom. It was originally released in 2011.
cannot see anything on screen when camera is on
cannot see anything on screen when camera is on but when picture is taken, it displays on camera
Questa è una buona domanda?
Punteggio 0
3 Commenti
dear markus
it work!
the instructions manual never said anything about this problem and i would have never solved it.
appreciate your help
thanks again, herb
da
hi herb, good that it worked. i've had a few powershots by myself and used this function sometimes
da
I dropped my camera and now the display is just blue. Can I fix it?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
you have most likely the display switched off.
press the disp. button until the live picture appears - the button switches between the different view modes
Punteggio 1
1 Commento:
%#*@! You can find out ANYTHING on the 'net. It worked!! Thanks so much.
da
Aggiungi la tua risposta
herb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,345
