Salta al contenuto principale
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
215 Domande Visualizza tutte
My gateway laptop is not connecting to wireless internet
i think my wireless card is broken .its not working but my wired internet is not working . please help ?
should i replace my wireless card ?
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
3 Risposte
Risposta Più Utile
hello,
there should be a sliding switch on the very side or back of it, bottom part with keyboard, check to make sure its in the on position. If it is, try looking for a Reset Wifi driver on gateways website, it would be able to set the "wall" of wifi back up.
Punteggio 7
just try following steps that might help -
just reset the adapter settings in wireless device and update the wireless driver and make sure time and date is also correct in computer . also check the wireless password and for more visit gateway http://www.gateway.com/worldwide/ and see if this works for you . let me know if you need anymore help
Punteggio 2
I was told locally that this is an endemic problem and can't be repaired. Can a used computer be scavenged for the bad part.?
Punteggio 0
1 Commento:
My laptop won't work either wired or wi fi. If it is just the io card can that be replaced?
da
Aggiungi la tua risposta
Richrad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 5,499
