Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
The container for bleach does not empty
There seems to be water in the spot where you add bleach
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
There is water that flushes through the dispensers after each load regardless of whether you have anything there or not. This helps in cleaning and flushing out the dispenser after each use. It is possible that there will be residual water in the dispenser after the cycle.
Punteggio 1
Aggiungi la tua risposta
mi2tall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 224
