Salta al contenuto principale
Guide di riparazione e smontaggio per telefoni cellulari fabbricati da Huawei.
1878 Domande Visualizza tutte
Huawei Ascend Mate replacement of digitizer only without lcd
I had my Huawei Ascend Mate's front panel broken, I bought a touchscreen (without digitizer). However, the repair man told me that Huawei Ascend Mates need the complete screen assembly replaced. The touchscreen only cannot be replaced as the digitizer and lcd are fused together. is it possible to use the new touch screen with the old lcd.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
How to tell which Screen part you need for the Huawei Ascend Mate MT1-U06:
LCD Only: If the image under the glass is broken and the touch panel is NOT then you only need an LCD.
Touch Panel aka Digitizer: If the top touch panel or aka glass top is cracked or broken but the image under it is fine then you only need the Touch Panel.
Complete Screen with Touch Panel and LCD: If the top touch panel is broken and the lcd image is either black liquid or cracked you need a complete screen.
Punteggio 0
I'm not sure you can change the Touch Panel aka Digitizer and not change the LCD. I tried it and had a disaster. Check before you buy!
Punteggio 0
Aggiungi la tua risposta
Bilal Haider sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,562
