Salta al contenuto principale
Xperia ZR is the waterproof phone from Sony that lets you film in Full HD underwater. Released in June 2013.
How to change loudspeaker after disassembly?
My phone was dropped into the toilet 2 weeks back but guess what I powered it on a couple of times after drying it immediately and it was flickering and didn't turn on after that. I then just left it on my desk till next day(20 hours from dropping), and it turned on and when i thought everything was fine all was bad.
The loudspeaker started making distorted(screeching) sounds after i raise volume over 25 %. Screen seems fine. But again front camera option goes missing on my camera app but rear camera is fine. I'm using android 4.3 by the way. Also, My battery life is so bad my phone restarts every time i connect the charger or even when I use it, phone automatically restarts every 5 - 10 minutes and it is really bugging me now.
I need to change my loudspeaker so i need assistance on how to do it step by step procedure wise. And I also purchased a spare battery to check if it was the battery causing all that restarting problem but it was not. Even the new spare battery situation was similar, phone restarts again and again and battery drains crazily.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
cr9foryou, it sounds like you have more issues than just a bad speaker.The importance right now is to not turn it on, or trying to sync/charge it. Remove the battery, and disassemble is right down to the logic board. Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Just like any other submersion, it is a bit of a guessing game as in how your phone will respond to a proper cleaning. Right now, everything will only be a guess, and the longer you wait the more corroded it will get. Hope this helps, good luck."
Punteggio 1
Had the same issue with a loud speaker after i replaced the screen of my Nexus 5X. Did you find solution on where is the loose/disconnect between the motherboard and the loud speaker module?
Punteggio 0
Aggiungi la tua risposta
cr9foryou sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 367
