Salta al contenuto principale
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76 Domande Visualizza tutte
spen not working on whole screen after lcd and digitizer replacment
I had replaced my screen after 60 days from broken.
The touch screen and everytging is working fine, except that the spen is not working in the whole screen.
Exactly acrectangle 2 cm below the screen top with length of 4 cm and width of the screen is not recognizing the spen, otherwise the spen works great.
What can be the problem ?
Thx
Ahmed Ismail
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Perhaps the digitizer itself is faulty, or maybe the stylus sensor film is damaged in the LCD and digitizer replacement you replaced. The s pen works through the stylus sensor film in the screen.
Punteggio 0
Had the same problem. Disconnected and reconnected the two big flex cables that connected screen to mither board.
Perfect after that.
Punteggio 0
I have had the same problem. Dropped the phone and had to replace the LCD Unit. Touch screen working perfect but S pen doesn't work anywhere on the screen except towards the top and lower parts of the screen. Pen detection sensor working fine. Do I need to get a new screen again ?
Punteggio 0
Aggiungi la tua risposta
ahmed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 4,746
