Salta al contenuto principale
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
Flickering screen when starting the smartphone
Flickering screen when starting the smartphone, then the screen goes off. Apparently smartphone presents normal operation although the screen does not turn more after starting the system.
Changing the Motherboard Flex Cable Ribbon I fix this?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your problem was caused by damaged LCD screen, not the motherboard flex ribbon. Replace a new LCD screen can solve it. The tutorial guide is here: Disassembling Nokia Lumia 920 and the part is here: http://www.etradesupply.com/oem-nokia-lu... Good luck.
Punteggio 1
2 Commenti:
Ok Mia, thanks very much. I will try here and give a feedback.
da
Today I replace a new LCD screen and the problem persists...
da
Aggiungi la tua risposta
vinnywebmaster sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 365
