Salta al contenuto principale
The Samsung NaviBot SR8855 is a handy autonomous vacuum by Samsung.
How to disassemble Samsung navibot SR8875?
Hi,
Would like to know how to remove the upper part of the navibot SR8875 ? I removed all screww but still locked in the front ?
If you want, you can also answer me in french (if you're french).
Thanks,
Matt
Questa è una buona domanda?
Punteggio 4
1 Commento
It is a bit tight but it will snap loose.That is if you have removed all the screw around it.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
You can find the service and disassembly manual here:
http://www.robotreviews.com/chat/downloa...
Best regards,
Imre
Punteggio 7
1 Commento:
Hi,
Thank you all for the link.
Matt
da
Hi
I can send to you a french PDF for that
Punteggio 1
Aggiungi la tua risposta
matthieubarbie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 6,259
