Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
No sound after speaker replacement
I'm having the No sound after speaker replacement. I went through every step exactly as shown and described. I am still not getting any sound through my earpiece speaker. What could be the problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
1st and foremost, why did you need to change your ear speaker? What happened? Was the old ear speaker working at all before?
2nd, to get you started, and if you were not hearing any sound to begin with, may be the ear speaker mesh is dirty. Poke 2~3 holes in the middle of the mesh using a fine needle. Do not insert it more than ~1 mm. If you start hearing better, then you need to replace the mesh, not the ear speaker (or leave it like this now that it's working). Try this and let me know.
3rd, it could be that the part you used is defective, or you received the wrong part. Where did you get it from? Does it look exactly like the ear piece you removed?
Punteggio 1
Hi, Thank you for your reply, I don't replace my earpiece speaker, i have problem with my screen and after i fixed it, i reassembled it and i did't do any thing with my earpiece speaker, but after i reassemble it doesn't work, now i thing maybe it has problem and replace with new one but still it doesn't work., PLEASE, PLEASE HELP ME, to understand the problem.
Punteggio 0
Aggiungi la tua risposta
davenachocamacho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 163
