Repair of sunroof so it will close/open
My sunroof is stuck in the 85% close position. Pushing either the open/close switch you just hear a 'rattat-tat' sound and the sunroof remains in the same position for most of the time. Some times it does move half an inch either way but that's all. I need to get under the headliner and be able to see if there are any small bolts loose/missing and what the track assembly looks like. Can you help and by chance also provide me with an excerpt from the factory service manual?
Update
Sure. I thought I included it. It's a 2006 Mazda 3 and is a 4dr. Can you also find info for removing a portion of the overhead headliner in order to be able to work on the sunroof motor and track assembly?
Thank you.
Questa è una buona domanda?
3 Commenti
Could you tell us what year the car is, so someone might find the factory service manual?
If it's 2010, a searchable PDF of the the factory service manual can be found here.
da Taylor Arnicar
ok-our problem is the 2004 Mazda 3's sunroof is stuck at tilt, and it make an awlful noise when trying to close it by pressing button. HELP!
da kam
Did anyone figure out how to fix a opem
sunroof that won’t close
da Malik
