Salta al contenuto principale
Released in May of 2013, the Xperia L is an Android smartphone featuring a 4.3" screen, 8 MP camera, and a dual-core processor. Identified by model numbers C2104 and C2105.
wi-fi is not working. how to repair it?
wi-fi is not working. how to repair it ?
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta Più Utile
First of all tell me if issue is the same booting your xperia in safe mode
Turn off the device.
Press and hold down the power key until the phone vibrates.
Wait until the Xperia™ logotype disappears.
Press and hold the volume down key. The device then restarts in safe mode.
To exit safe mode, restart the device.
So if your phone works fine in safe mode probably issue is caused by
- a conflict with a third party app that you installed after purchase
- firmware corrupted
So first of all you can remove all recent third party apps and if issue persists make a factory reset.
Remember that with reset you will loose all your datas.
for more information, https://talk.sonymobile.com/t5/Xperia-L/...
Punteggio 2
1 Commento:
I did all above steps and still the issue persists, I also tried by repair software option through PC companion.
da
the phone has wifi problem that is activated each time the phone is turned off and turned on automatically
Punteggio 0
3 Commenti:
did you get solution
da
the same problem is happening with me please tell any solution
da
this problem not solving with software repair, this killing me. Please solve it
da
Even I'm facing the same issue. when I switch on wifi..... Phone hangs and start keep on rebooting.
When I visited Sony service , they said it's the motherboard compliant.
This is what I got answer from Sony service center.
Bloody Chinese Mother f-ckers.
Punteggio 0
Aggiungi la tua risposta
ahmedsaleh1985 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 7,959
