Salta al contenuto principale
A 3G smartphone also known as the Samsung i9000 Galaxy S, or the Samsung I9008 Galaxy S in the Chinese market, released Spring 2010.
44 Domande Visualizza tutte
Phone wont charge, and it used to be really hard to charge?
Hey, I have a samsung galaxy S. I've had it about 2 years and before that it was someones elses for maybe a year or two.
Anyway, about a year ago it was quite hard to charge and I had to sometimes put it on a certain angle for it to charge but eventually that went away after a month and started charging normally again.
But recently its been really difficult to charge and now it wont charge at all! I've tried scraping the usb port for lint and I've tried taking out the battery and I use all sorts of different chargers so that isn't the problem (unless its because I'm using off-brand chargers?)
I have dropped my phone quite a lot too so that could be the problem but I'm not sure..
I'd like to be able to fix it without going to a repair shop but I will if its necessary
Thanks! :)
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
Kayla, start off with a new battery. If that still does not work properly I suggest to replace the charging port on your phone. Yes, inexpensive aftermarket chargers can cause issues with the PWM IC
Punteggio 2
try a new cable first, all my samsung phones have done this over time, and a new cable brings them to charge like new, that cable its self is designed to wearout faster than the port on your phone.
Punteggio 1
Aggiungi la tua risposta
Kayla sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 944
