Salta al contenuto principale
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Stange Screen Colors after LCD Replacement
Hi,
I have made a LCD replacement with the guide. But when I turn on the phone, I see strange colors on the screen (check attached image).
I have even tried with different working LCDs, checked if connections were well seated,.. same problem.
Can you tell me what could be the problem?
And by the way, if there's something I could test or change?
Thank you very much.
Questa è una buona domanda?
Punteggio 1
1 Commento:
I have the exact same problem. Anyone with a fix?
da
Aggiungi un commento
2 Risposte
Some post on XDA says that the USB flex might be the problem. I'll try to change it next week and see if it works ;)
Punteggio 0
1 Commento:
Unfortunately it didn't work, still same screen
da
motherboard issue i have the same problem. Is the connector of usb flex.
Punteggio 0
Aggiungi la tua risposta
NiA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 529
