Salta al contenuto principale
Guides for small kitchen appliance repair and disassembly. Kitchen appliances have long helped people fix dinner. Return the favor, and the fix your appliances when they break.
3526 Domande Visualizza tutte
Kitchen scale power button works intermittently. Fix or replace?
Hi. I have a Salter kitchen scale (Model 1008USSSBKDR) and I have to press the "on/power" button numerous times before it powers up. Seems to work fine once it does finally turn on, but I can push it (literally) 200 times before it works. most times I just give up.
I really like the scale, and it wasn't cheap. I'm wondering if I can somehow fix it. Not very electronically savvy, but I am mechanically minded and I'm game for a challenge. Thank you in advance!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
I had two similar salter scales (model 1051) which were very difficult to turn on/off after some use. Changing batteries and licking fingers didn't work. The fix is easy, just clean the switch(es) with a solvent to remove the almost invisible coating (patina) that builds up from the grease on your fingers. Both my scales are now working like new. I used a tiny bit of 100% alcohol on a q-tip (cotton bud) and rubbed the touch-switches for less than a minute. I'm sure lots of other solvents will also work.
I discovered this when taking the scales apart to fix ithem and noticed that touching the inside surfaces of the touch-switch (where there was no grease layer) successfully turned the scales on.
Punteggio 0
2 Commenti:
Also worth mentioning that these scales need batteries near 1.5v. So NiMH rechargeables must be fully charged to about 1.4v ( nominal value is 1.2v). These rechargeable batteries also loose charge over a few months.
da
I found taking the back off and cleaning out the cobwebs (yes, amazing how they get there) made turning on much easier. I have read that cobwebs are conductive if relative humidity is about 40% (60-70% in out house).
da
Aggiungi la tua risposta
danielmillen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 48
Tutti i Tempi: 5,423
