Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Water Damaged iPhone 6
My iPhone 6 just got dropped into water and i quickly got it out of the water, but the phone has been not been able to turn on since. I tried to completly teardown the iPhone and laid it into rice over a couple of nights. When i reassembled the iPhone it still didnt work. I tried next to replace the Charging flex and charged it for 1 hour, and the phone started to get warm(battery) but didnt turn on.
Do anyone have any tips maybe parts that could be replaced to repair the iPhone or is the phone dead?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
The most important part which should be payed attention is the motherboard.So take the motherboard to test, if it dead, your phone dead.
Punteggio 1
Risposta Più Utile
Step 1: clean the logic board with generous amounts of 90%+ isopropyl alcohol and a soft brush. Dry with warm air.
Disassemble the screen and pat dry all the water. Don't apply alcohol to the screen.
Reassemble and test.
If this doesn't help, disconnect the battery and seek further help here.
Punteggio 2
When dropped in water Must remove battery and full wash.........
Now your Phone Dead
1) disconnect motherboard battery,Lcd Etc..
2) Check motherboard short or Not
water damage 90% Phone motherboard short. If You find When Short i hope You can Repair YoUr Iphone.........
Thanks
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,729
