Salta al contenuto principale
Cleaning action went wrong, now my Mac has Problems to start
Hi guys,
something stupid happend to me.
I tried to clean my keyboard and wiped with a tine sponge (sponge for cleaning a Fotocamera-sensor) between the right side of the EJECT-key (the key you press to get the CD out of the optical drive) and the case.
Suddenly the sponge slipped between the Eject key and the case and disappeared.
I released the eject key and tried to pull the sponge with a sharp metall tweezers (that was the only tool I had in this moment, probably a stupid choice?!) out .
I got almost everything out.
Everything was working fine at this moment.
But in the night I watched a film via VLCplayer in fullscreen and my Mac freezes. I did a cold restart (pressing the On BUtton several Minutes). Everything was fine again.
4 Days later I burned 20 DVDs and in the evening I watched a film again via VLC player full screen mode and it freezes again, so I had to shut it down hard (press On button).
But since than the tragody begann. It didn't want to start. It just showed a gray screen with the turning symbol and after 2 minutes the gray curtain cames with the white words *you have to restart you computer ...*.
I tried to start in SafeModus, that worked one time. The mac started properly again.
But the it freezes again while I was wathcing an internetstream via firefox.
Just stuff happend to me to often the last days.
So it could be a software problem or maybe I destroyed something with my cleaning mistake??? So that disconnection is the problem.
Do you have any idea?
I already released and reassamble the RAM (but Mac still doesnt start). BEcause I thought maybe they are not properly on there place. I used my Mac 2 weeks ago in the car while we were driving off road. And 6 month ago it had fallen down from the sofa on its left side on to the eletricity-plug.
And some friend said, maybe a part of the sponge came into the right fan. Put it sounds the same like everytime. Or how can I figure out if it's working?
I think the sponge sliped on to the display cable. it also sounded like tipping on plastic when I was in there.
Thanks a lot for you help and suggestions.
Sorry for my english mistakes, it's not my mother tongue. Hopefully I used the wright words t:-Do discribe my problems.
Cheers
Duderit
Update
HI, I did let repair my Mac.
It was the NVIDIA GeForce 8600M GT graphics processor Warranty.
http://support.apple.com/kb/TS2377?viewl...
:-D
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you're ready to DIY
open it up and see if there's sponge parts floating around inside! You can't just leave a foreign object in there.
The fact that the strange behavior started after losing something inside points towards that being the cause of your problem.
The "grey screen" is a kernel panic - they can be caused by hardware OR software (I lean toward hardware because a foreign object was dropped into the case).
If the sponge was wet corrosion could be developing inside, it can be cleaned off with a soft brush and 99% alcohol (brush carefully).
If this answer is acceptable please return and mark it.
Good Luck,
N.
Punteggio 1
1 Commento:
HI Machead,
I opened it up yesterday. Inside everything looked fine. No scratches, no corrosion and no spongepieces. Just some dust. But after 4 years it look very well inside. I expected some dead ants inside ;-).
So I think and hope it is a kernel-panic, caused by software, so that a scan by discutility or at the end a reinstall will solve the problem.
I will report when I hopefully get my MBP run again.
Kind regards
da
Aggiungi la tua risposta
Duderit sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,708
