Salta al contenuto principale
Remove broken screw from retaining bracket
Inside my MacBook Pro 15" (Early 2008, model A1260) there are 2 screws that hold down the hard drive retaining bracket. One of the screw heads broke off, leaving the entire screw in the bracket with nothing to cling onto. I am now unable to remove the screw, which in turn won't allow me access to remove the hard drive. Is there a way to remove the broken screw?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Is the head completely gone or is the torx "round" ?
whe the head is completely gone, it would be the easiest thing to remove the drive - without the head - it can hold nothing
but when the head is still there, but round - use a screwdriver that almost not fits on the screw (a little bit larger than the round hole) - press it in the screw and screw carefully - that way i always get the dead torxes out (ok, to be honest - i do something more often than others and in hardes cases - i use my dremel ;-) )
Punteggio 1
The screw head completely broke off. The screw stem is screwed into the retaining bracket holding it securely in place.
Punteggio 0
Aggiungi la tua risposta
Archie Korbiel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,381
