Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Domanda Chiusa
The keyboard has a bright spot in the middle keys
I have a late 2011 MacBook pro I received as a giveaway. I upgraded the memory to 8 gig, upgraded the hard drive to a 240 gig ssd. Upon upgrading, I realized the keyboard has a bright spot in the middle keys. All keys are illuminated. It just has a bright spot in almost a v shape in the middle keys. Should I be concerned? Is there a recommendation? Replace the keyboard? Possibly some inning for me to check in the system?
The last 4 numbers of the serial number is DV13. The keys affected by bright spots:
5,6,8,t,y,u,g,h,n,v
Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Anyone?
Punteggio 0
Risposta Più Utile
Do you know if this computer is a liquid damaged one ? If all the keyboard keys are working well you just have to replace the keyboard backlight assembly. Check on ebay I think it's about $30.
Punteggio 1
It's possible of course but I doubt it. It runs perfectly except for the brightness on these specific keys.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 214
