Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
display brightness not increasing or decreasing
I have a samsung galaxy s3 i9300. Its screen got cracked so gave it to a local repairer.he replaced the whole display and touch.the touch is working fine but now the display brightness is neither increasing nor decreasing. So my question is.is there any problem in display?
Questa è una buona domanda?
Punteggio 12
1 Commento
sir mera samsung j5 ki brightness work nehi kar rahi ha ji kya karu ma plz.. mare problem ko solve karo ji
da
Aggiungi un commento
10 Risposte
Risposta Più Utile
The replacement screen u got is an lcd whereas the original one is an led.thats why the brightness cannot be controlled
Punteggio 7
2 Commenti:
but there aren't a solutions for brightness check with an led display?
da
I would have believed this until I used a 3rd party app to check control brightness, that worked perfectly fine. I would try a phone reset but right now using the app.
da
Hi Nitish,
Are you sure auto-brightness is not activated?
Perhaps energy saving is enabled?
To test everything with your screen i suggest you launch the test menu and see if everything works there, there is a special button called "dimming" there to test as such;
-> go to your "keypad" (as if you want to call somebody)
-> Type in: *#0*#
It should start the test menu instantly.
Let us know what the tests do :)
Punteggio 3
1 Commento:
In dimming test it showing three colours. Red,blue and green. Nothing else is happening
da
go to play stor install apk name NIGHT MODE it can be easly fixed
ukrain rx
Punteggio 2
If you have replaced your display folder then sometimes you face this problem , because of cheap quality display folder .
For this you have to download night mode application from play store .It will work for you.
Punteggio 2
Reset your device and off the auto power saving and try again
I think its work unless there is a hardware problem
Punteggio 0
If you have changed your phone display then it might create problem because some china display doesn't have the hardware that support display brightness. If not so then try factory data reset this might work.
Punteggio 0
Yes bro u are right? This happens to me also,it is only because shop owner replace not the original folder infact any third class , cheaper folder?
Punteggio 0
My mobile brightness not increase problem samsung j7
Punteggio 0
First check the auto brightness option,This is the symbol of copy Lcd only to display the graphic not controlled light system and phone also goes to heating up problem better to change original OLED LCD.
Punteggio 0
brightness not working samung c7000
Update (09/17/2019)
Punteggio 0
Aggiungi la tua risposta
nitish tokas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 43,034
