Does this work for the kurio c14100/c14150 model?
I see the kurio on the pictures is the c11100 model. Does it share the same lcd as the c14100/c14150 model?
Questa è una buona domanda?
1). With the power completely off, press and hold the VOLUME DOWN button.
2). With the Volume Down button still held, press the POWER BUTTON to turn on your device.
3). Once the device powers on, you may release the power button. Do NOT let go of the VOLUME DOWN button
4). Use VOLUME DOWN to go to RECOVERY and use the POWER BUTTON to select it.
5). Use VOLUME DOWN to go to WIPE DATA/FACTORY RESET and use the POWER BUTTON to select it.
6). Use VOLUME DOWN to go to YES - DELETE ALL USER DATA and use the POWER BUTTON to select it.
7). Once complete use the POWER BUTTON to choose REBOOT SYSTEM NOW.
When holding VOLUME DOWN first, press POWER BUTTON for about 3 seconds to turn on and then follow above instructions (holding VOLUME DOWN as it powers on ). I was holding them both down for 10 seconds (like other sites suggested with VOLUME UP.) I tried VOLUME UP (for other models?) and VOLUME DOWN but nothing worked until I only pressed POWER BUTTON for a few seconds to turn on. Thanks for the steps above. ^_^ I have the C14100/C14150 as well.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,343
2 Commenti
Hi there,
any ideas on what to do if the reboot stalls? We're stuck on app 18/61....
da S E
Donde compro repuestos para esta tablet kurio modelo c1400 táctil y pantalla??
da alexander.202009
