Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Domanda Chiusa
SSD replacement
Hi
I have a iMac Intel 27" EMC 2429 with a SSD 256GB & 1TB HDD.
Do I presume that the replacement of the SSD is the same as the Dual Drive Kit install EXCEPT my system already has the cabling and the SSD behind the optical drive, so I don't need to do steps 17 - 33?
But I am guessing where the SSD would be, can you confirm?
Simon
Questa è una buona domanda?
Punteggio 0
1 Commento
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You know the old saw about Assumptions. Study the guide and notes (not just look them over) before starting.
Obtain the recommended tools, every job is easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it accepted.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 327
