Salta al contenuto principale
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Domanda Chiusa
Why is my display not working?
I fell in sea with my note 3 in pants may be about 2 or 3 seconds. Afterwards I dried it up in AC and turned it on. Everything works except the display. Even the touch is working. Kies also recognizes it so I backed-up all my data. Is there anyway I can factory reset it or do any recovery with or without kies ? Do I need to replace the entire LCD screen with housing ? Please help me.
Questa è una buona domanda?
Punteggio 0
1 Commento
You can try to replace the LCD screen,but with it being water damage the likely culprit is located on the board. how long did you wait before you turned it on after it was in water?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hey,
Sorry about your Note 3, that is a real bummer.
First thing is first, water damage is tricky, and sea water is full of impurities. Take the phone apart, and treat the motherboard for water damage. If you don't have the proper facilities, a good scrub with isopropyl alcohol (at least 90%) will certainly give the phone a better chance of survival. It is possible that corrosion has set into your screens ribbon flex, or the connector on the motherboard itself.
Unfortunately, since the device was turned on, and plugged in, there is a good chance you will need to replace the LCD, and since the device had power sent through it after being wet, the display may never come back. Certainly better to try though, as you may have a perfectly fine device that just needs a new display!
Good luck.
-Samantha S. Device Savers
Punteggio 2
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 130
